UCM 7.0 softkeys not functional during offnet Call connected state
May 7th, 2010
Hi All,
I have an issue with UCM, when on an offnet call the softkey in the connect state are not functional except the Endcall.
Please any idea.
Olalekan Amsuat
William Bell Fri, 05/07/2010 - 04:42
  • Purple, 4500 points or more
CUCM does not differentiate softkeys present based on call classification (i.e. OnNet vs. OffNet).  The presence of "End Call" only is typically on the Connected - No Feature line state.  An example of this line state is the Intercom connection (using Intercom lines).  Since you can't Intercom Off Net then I suspect that it is either a phone model/feature thing or the softkey template is configured to only show "End Call".  There is a remote possibility there is a software defect (I haven't searched).
Some questions:
1. What model phone?
2. Does this happen on all phones or just one or one type?
3. You specify Off Net.  Do you actually see a difference in behavior between On Net/Off Net?
4. When you experience this issue, do you see other softkeys and they don't work or do you only see the "End Call" softkey?
Bill
lamusat007 Fri, 05/07/2010 - 04:52
Some questions:
1. What model phone? 7940, 7941, 7960, 7961
Yes
Yes. For On-net calls all the softkey bottons in the connected state are active, and can transfer calls.
But for offnet calls in the connected state only Endcall softkey is active.
I see other softkey, none other that the End Call is functional.
Jaime Valencia Fri, 05/07/2010 - 06:32
  • Cisco Employee,
  • Hall of Fame,
    2011
Are you using H323 GWs???
If so, make sure the MTP required is check on the GW config and that MTPs are available via the MRGL.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
lamusat007 Fri, 05/07/2010 - 06:42
It is a Sip trunk, I didn't check the MTP check box. In my MRG there is no Transcoder thou. Could that have an effect.
