How check file exists on USB_2/USB_1 in java script before displaying it
May 7th, 2010
I would like to check whether file exists or not on USB_2/USB_1 using java script before displaying it.
So that I can avoid file not found error.
Please advise.
Anantha
Tomas De Leon Wed, 05/12/2010 - 07:46
  • Cisco Employee,
There is not a feature to do this.
You would need to use the API & MIBs and personalized screens to check to see if the file
is there and then play out the file.  Some knowledge of programming and working with
the APIs & MIBs could probably accomplish the tasks that you want but I would imagine
there would be some delay while doing all of the checks.
Thanks for the Question and Good Luck!
T.
