Vocie gateway D channel down by losing network connectivity to CCM?
Answered Question
May 7th, 2010
All,
Is there any possibility that losing network connectivity to call manager will bring down ISDN D channel on voice gateway or it is totally non related? I am running MGCP between voice gateway and CCM.
Correct Answer by William Bell about 6 years 11 months ago
Absolutely.  With MGCP, the ISDN Q.931 is backhauled to the CUCM.  This means that CUCM controls the D+B channels.  If CUCM is dropped (fault in host, network, etc.) then your Q.931 protocol exchange ceases and your D-channel (and B-channels) are dropped.
HTH.
Bill
Please remember to rate helpful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
William Bell Fri, 05/07/2010 - 06:50
  • Purple, 4500 points or more
HTH.
Bill
David Hailey Fri, 05/07/2010 - 07:05
Most definitley. MGCP is backhauled to CUCM so connctivity issues
would result in losing the primary D Channel and the B channels. In
some instances a carrier flap may only show a D channel down but if
you know you lost connection then that would be the primary issue.
Sent from my iPhone
On May 7, 2010, at 9:43 AM, yuhuiyao
