05-07-2010 07:13 AM - edited 03-17-2019 10:00 PM
When I upgraded to use TelePresence phone midlets from the older XML services method, the Phone UI displays the proper TelePresence User interface but my other legacy Services fail to run properly (e.g. clock.asp from the IP Phone services SDK). When I press the phone services button and select the clock it begins to launch and then gets interuupted and the midlet reloads.
The legacy services work fine on standard VoIP phones but not on the TelePresence phones with midlets. Is there a compatibility issue between TelePresence phone Midlets legacy phone services? Is there a work arround for this issue?
Jim
05-10-2010 11:50 PM
The midlets in TP phone wont allow you to load a different XML service at the same time, thats expected behavior, any reason you want to have both?
05-11-2010 06:32 AM
I wrote an XML phone service to query the CTMS and return the multipoint session details. My customer wants to validate participants who dialed into the static multipoint bridge, then lock the meeting for privacy. The service will launch and run and then gets interrupted by a midlet reload initiated by the CTS codec. I tried changing the idle timer but I get mixed results.
05-11-2010 04:45 PM
Hi James
Thanks for the clarification, for this one I would engage your local cisco AM, they can redirect you to our dev team/BU which can help you to customize your solution
