UCC Server - displaying phone status
May 7th, 2010
With UCC Server 1.5.1, the status always shows the users line as idle.  Is there a way to configure it so it shows when the user is on the phone?  Everything else seems to be working with the CallConnector server as far as Availability status, IM, etc.  We would just like to be able to see when someone is on the phone.  Is this possible?
Brian
greenturtlesteak Fri, 05/07/2010 - 07:57
If you stop the UCC services and go into the server configuration wizard are you able to see the radius messages sent from the router to UCC?
Cole
shtalukd Fri, 05/07/2010 - 12:37
Hi Brian,
I've attached the sample of the radius configuration. Would you please double check if it is configured correctly in your CME?
Another possible cause: if you restrict a group to receive caller-id and presence status for groups in Server Wizard, users in this group can't receive call/presence status from restricted group.
Hope this resolves the issue. Otherwise, can we setup a webEx session to get this resolved? Please provide us your email address and let us know when is a good time to connect, then I'll send you a webEx invitation.
CallConnector Team.
brian-schultz Tue, 05/11/2010 - 05:37
Thanks for the sample radius config.  There are definitely some commands there that I do not have configured.  I will try this out and will let you know.
Brian,
I posted the same question before, the only status is if you expand the Call connector contacts and see if they are on the line. Is this where you are looking or are you talking about the red, green, yellow orb? If the later, this is just a setting the user can select and it does not have any bearing on the line status.
Bob
brian-schultz Tue, 05/11/2010 - 05:39
Bob,
I'm looking for the status of if they are on the phone or not.  Currently, all phones show idle if they are on the phone.
The orb for Available, Busy, etc. works just fine, but that doesn't change automatically if you are on the phone (which maybe it should).
I'm going to try the radius config example later today and will post back.
Brian
