Need Assistance Upgrading NM-CIDS on Cisco 3845 router.
lei.silva
Can anyone tell me all the files that I need to upgrade my IDS from 6.0(5)E3 to 6.0(6)E4?  I believe I should be able to do this with the hardware I currently have.  I don't have the resources to upgrade the router or NM-CIDS module.  I want to update to the E4 because it appears Cisco is no longer putting out signatures for the E3.  From the documentation I'm reading I will need at least the System Image, the Service Pack, the Recovery Image, and the Engine Update files.  I see several different file times that have AIM in the naming convention.  I'm uncertain what specific file names I will need.
A show version capture is below.
show version
Application Partition:
Cisco Intrusion Prevention System, Version 6.0(5)E3
Host:
    Realm Keys          key1.0
Signature Definition:
    Signature Update    S479.0                   2010-03-19
    Virus Update        V1.4                     2007-03-02
OS Version:             2.4.30-IDS-smp-bigphys
Platform:               NM-CIDS
Serial Number:          FOC11014468
Licensed, expires:      14-Aug-2010 UTC
Sensor up-time is 17 days.
Using 403263488 out of 509292544 bytes of available memory (79% usage)
system is using 17.7M out of 29.0M bytes of available disk space (61% usage)
application-data is using 34.1M out of 174.7M bytes of available disk space (21% usage)
boot is using 39.1M out of 75.9M bytes of available disk space (54% usage)
application-log is using 532.3M out of 2.8G bytes of available disk space (20% usage)
MainApp          N-2008_JUN_06_02_35    (Release)   2008-06-06T03:23:18-0500   Running
AnalysisEngine   NE-2008_OCT_16_22_05   (Release)   2008-10-16T22:30:37-0500   Running
CLI              N-2008_JUN_06_02_35    (Release)   2008-06-06T03:23:18-0500
Upgrade History:
* IPS-sig-S478-req-E3       18:12:38 UTC Mon Mar 22 2010
  IPS-sig-S479-req-E3.pkg   14:00:57 UTC Fri Mar 26 2010
Recovery Partition Version 1.1 - 6.0(5)E3
You only need the IPS-K9-6.0-6-E4.pkg file.
Put it on a FTP server and jump on the sensor CLI and run this command:
upgrade ftp://(username)@(ipaddress of your ftp server)//(directory, if any)/IPS-K9-6.0-6-E4.pkg
- Bob
rhermes
Level 7
Level 7
From the software download section on CCO, follow this branch:
http://tools.cisco.com/support/downloads/go/Model.x?mdfid=282539293&mdfLevel=Software%20Version/Option&treeName=Security&modelName=Cisco%20IPS%20Sensor%20Software%20Version%206.2&treeMdfId=268438162
Intrusion Prevention System (IPS)
     IPS Appliances
               Cisco IPS Sensor Software version 6.2
Installation instructions:
http://www.cisco.com/en/US/docs/security/ips/6.0/installation/guide/hwImage.html#wp1142504
- Bob
I've got the instructions.  I needed to know which specific files I need to use.  I'm guessing the following:
IPS-NM_CIDS-K9-sys-1.1-a-6.0-6-E4.img as the system image
IPS-K9-6.0-6-E4.pkg                               as the Service Pack
IPS-K9-r-1.1-a-6.0-6-E4.pkg                     as the recovery image
IPS-engine-E4-req-6.0-6.pkg                    as the Engine Update
I've been previously told that I can not go to Cisco IPS Sensor Software version 6.2 because my hardware will not support it.
Can all of these files be updated through the IDM?
- Bob
