Entering username and password in URL, 4400g, v5.2 ??
Answered Question
May 7th, 2010
Correct Answer by Tomas De Leon about 6 years 8 months ago
Sorry, this type of functionality is not available on the DMP.
A lot of the responsibility resides on the Hosting Site on how it
accepts the authentication or Login credentials.  A web or app savy
developer could probably develop a App (like for iPhone or iTouch)
which could bring up a Virtual Keyboard which could be used with
the DMP-4400G and a supported Touchscreen.  Then the user could
add the credentials using the touch screen.
Cheers!
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
Overall Rating: 5 (1 ratings)
Correct Answer
Tomas De Leon Fri, 05/07/2010 - 09:54
Cheers!
Thank You!
T.
Viten Patel Fri, 05/07/2010 - 12:10
Is there a work around? Without developing an App or anything. The host website is not under my control so any modifications from their side is virtually not possible.
Tomas De Leon Fri, 05/07/2010 - 12:27
What is the URL link?  so I can see what type of Authentication challenge it is asking for?
* What type of website is it like?  Is the Website a site like www.cisco.com where you can
  access it but to get more detail you need to login?
* Is it a situation where data is behind a VPN and you need to authenticate first via web before
  access is granted?  Similar to our Cisco VPN\ECT routers...
In General, there is no workaround.  Remember, there is no way to send input (like keyboard) or add a response from the
DMP other then Touch Screen.
T.
Viten Patel Fri, 05/07/2010 - 12:32
The URL is www.cisco.com, it is basically a case queue website. I think I did a NSlookup and I believe the server is on 172.x.x.x but I maybe mistaken.
Tomas De Leon Fri, 05/07/2010 - 13:22
Viten,
you are out of luck here.
Sorry.
Note:  Please do not post internal IP address' or names on this Public forum.
Also, you can use internal email  alias for stuff like this.
Cheers!
T.
Related Content
