Wireless client does not resolve DNS
May 7th, 2010
I installed Controller 4402 with 44 1252 APs.  It just seems the wireless network is not passing dns info when a laptop is connected thru wireless (only able to ping by its IP adress) , but when same machines  are wired they communicate fine by machine name.
Both networks are in the same subnet.
Thanks for providing the answer.
George Stefanick Fri, 05/07/2010 - 17:05
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Do you have a virtual address set on your WLC if so what is it?
balajirajahpb Wed, 06/02/2010 - 04:47
You need to check how the DHCP scope is defined for the wireless client. Under Controller--> internal DHCP Server--> DHCP Scope--> verify the DHCP scope and DNS server address pointed to.
