Help with 2620xm home network with cable modem SB4100
May 7th, 2010
Hi everyone,
I'm trying to set up a home network with Cisco 2620xm (1fa) with cable modem SB4100 through a 2950 switch, but can't get it to work.
I set up 2 Vlans..  Vlan 10 fa port 2 for cable modem, Vlan 20 as access ports for the rest. Port 1 is set as trunk which connects to router.
Router has two sub interfaces fa0/0.10 172.16.1.0 as IP NAT outside network for Vlan 10 and fa0/0.20 192.168.1.0 as IP NAT INSIDE network for Vlan 20.
IP route 0.0.0.0 0.0.0.0 172.16.1.1
ACL was set as standard to permitting the networks and Nat is linked with ACL and set to overload.
There is a catch in which my ISP uses DHCP assigned ip, however, it hasn't changed for a very long time.
There are definite faults in my setup but I don't know exactly what it is or if it's even workable because I read on other forums that a 'NAT on a stick' is needed with a loopback address.
Also there is the problem with the cable modem with one max mac, so I switched CDP, Keepalives, STP off on port 2.
Can someone please point me to the right direction?
Giuseppe Larosa Sat, 05/08/2010 - 02:55
Hello Matthew,
it is not clear if you have already done this.
However, you can make the router to get an ip address by DHCP service on cable modem like a PC by using
int f0/0.20
enc dot1q 20
ip address dhcp
no shut
on C2950 the only ports in vlan20 have to be port to cable modem and trunk port to router fas0/0
you can also use the DHCP option in a static route like
ip route 0.0.0.0 0.0.0.0 dhcp
in order to be able to deal with possible changes over time
on switch port to cable modem:
no cdp enable
spanning-tree bpdufilter enable
switchport nonegotiate
! to switch off DTP
you don't need a loopback in your setup.
Hope to help
Giuseppe
Paktol1088 Sat, 05/08/2010 - 13:04
Hi Giuslar,
Thanks for your reply, I've tried a number of diferrent config based on your reply but it's still not working.
Fristly, what do I do with the other vlans? move all access ports to vlan 1?
second, 0.0.0.0 0.0.0.0 'DHCP' isn't an option with my router.Is this normal?
Port fa0/1 is set as trunk and fa0/2 (cable modem) is on it's own vlan
Giuseppe Larosa Mon, 05/10/2010 - 02:54
Hello Matthew,
sorry I did an error the syntax to use the DHCP option in a static route is:
! checked on a C2811 with 12.4(15)T
ip route 1.1.1.1 255.255.255.255 f0/0 dhcp ?
so in your case becomes
ip route 0.0.0.0 0.0.0.0 f0/1.10 dhcp
if you have other vlans / IP subnets and you want them to access the internet you need to add ip nat inside under the Layer3 subinterface
all LAN switch ports should be in a vlan different then vlan 10 or some user can access directly the cable modem.
in vlan 10 you should have only the trunk port to router and the port to cable modem
Hope to help
Giuseppe
Related Content
