port fast and 3500 XL Switch
Answered Question
i got 2 3500 series XL switches for labing. I already know that I can't use int range for configs because of the old IOS 12-0-5.WC17, its actually the highest one that can run on it, memory limitations for higher IOS i gather.
Anyway, is there a way to add portfast to all access ports on this so i don't have to do it manually for all ports. Thanks
Correct Answer by Reza Sharifi about 7 years 2 weeks ago
There is no other way.  You have to do it one at the time for each interface since the interface range is not available
Reza
Overall Rating: 5 (1 ratings)
Correct Answer
Reza Sharifi Fri, 05/07/2010 - 18:24
  • Cisco Designated VIP,
    2017 LAN
Reza
