Warning message
IP NAT command
Answered Question
May 7th, 2010
  • Blue, 1500 points or more
hi experts,
i would like to know if all ports (i.e. 80, 25, 443, etc) are enabled by default when i use this command:
ip nat inside source static <localaddr> <globaladdr> extendable
could someone enlighten me or expound on the keyword "extendable" below:
"Extendable" static translations:
The extendable keyword allows the user to configure several ambiguous static translations, where an ambiguous translations are translations with the same local or global address.
Correct Answer by andrew.prince@m... about 7 years 3 months ago
To answer you question:-
Yes - ALL ports are enabled.
The extendable keyword allows you to configure  several ambiguous static translations, where an ambiguous translations  are translations with the same local or global address. This option just allows you to "Extend" the translation beyond simple IP!
HTH>
Overall Rating: 4 (2 ratings)
Correct Answer
andrew.prince@m... Sat, 05/08/2010 - 00:34
  • Green, 3000 points or more
HTH>
Jon Marshall Sat, 05/08/2010 - 02:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
johnlloyd_13 wrote:
hi experts,
ip nat inside source static extendable
John
As Andrew says it does indeed enable all ports but for a specific circumstance. If you simply want to enable all ports for a specific local to global address then you don't need the extendable keyword ie.
would do the job.
Jon
johnlloyd_13 Thu, 05/13/2010 - 05:35
thanks for your inputs! appreciate it!
