DMZ and web server
May 7th, 2010
Dear All
I have A web server in my DMZ of network,
internet----ASA----DMZ
The issue is I want to give my web server and invalid ip address like 172.x.x.x
but I dont know how can I bind valid ip address into this web server
my valid ip address is 61.x.x.1 i set this ip as my outside interface
my web server will be 61.x.x.2
but i do not know where 61.x.x.2 should be set..i tried to set this ip address into DMZ interface but asa rejected because overlap with my outside interface.
should this ip set (61.x.x.2) on my web server or asa or where?
thank you
Jennifer Halim Sat, 05/08/2010 - 01:33
  • Cisco Employee,
You can configure translation on the ASA for the web server.
For example:
Web server ip address is 172.16.1.2, and you would like to translate it to public ip of 61.x.x.2:
static (dmz,outside) 61.x.x.2 172.16.1.2 netmask 255.255.255.255
For outside hosts to access the web server from the Internet, you would need to configure access-list to allow access.
For example: if you need HTTP and HTTPS access to the web server, then configure the following:
access-list outside-acl permit tcp any host 61.x.x.2 eq 80
access-list outside-acl permit tcp any host 61.x.x.2 eq 443
access-group outside-acl in interface outside
Hope that helps.
