mgoon Mon, 05/10/2010 - 16:47
Hi Benjamin,
Thanks for letting us know about your problem. We’ve asked our IT and tool support teams to investigate whether there might be a compatibility issue. In the meantime, I can email you a PDF file of the Cisco IOS XE release notes if you would like to provide me your email address ([email protected]). I’d also like to ask if the release notes file is the only document you have a problem opening on Cisco.com with IE 8 on Windows 7, or have you had similar problems opening other Cisco docs?
-Mary
