Unable to VPN to RV042 in same location.
May 8th, 2010
Setup is: Cable Modem ------> RV042 (WAN IP: 172.x.x.x, LAN IP: 192.x.x.x) ------> Wireless Router (LAN IP: 10.x.x.x, Wan: 192.x.x.x, Gateway: RV042) -----> Client (IP: 10.x.x.x, Gateway: Wireless Router).
I want to VPN to the RV042 but am unable, even if I put the RV042 WAN ip address. I am able to easily connect to RV042 using PPTP tunnel with built-in Microsoft VPN support; however, I actually want to create a more secure tunnel (VPN) to the RV042 but all I see in the Log is that the QuickVPN software is "Remote gateway wasn't reached". Has anyone been able to use QuickVPN to establish a VPN tunnel to their RV042 inside the network?
cchamorr Mon, 05/10/2010 - 15:03
Ok, I have a lot of questions; basically I didn't understand the purpose of the VPN connection or how you are trying to accomplish it.
- First of all, why do you need a VPN connection on your internal LAN?
- Second, what is the other end of the connection? Where are you trying to connect from?
- How are you connecting using PPTP?
Please post some more information about this so we can understand it better.
mohamedtag Tue, 12/21/2010 - 12:51
Emesal ,
Change the RV042 LAN IP Address to any other IP Address /  Subnet other than 192.168.1.1. ( Default IP Address ).
Related Content
