Call restriction on Call Manager
Answered Question
May 8th, 2010
I want to restrict local or long distant call on specific dn. How can I do that?
Thanks.
Correct Answer by David Hailey about 7 years 2 months ago
Create local and LD patterns you want to restrict (specific or generic patterns based on requirement) and put them into a Partition called COR_PT or a name of your choice.  On each pattern select, block this pattern.  Create a CSS that inlcudes the COR_PT and assign it to the LINE level of the phone you wish to restrict calling for.
Hailey
Please rate helpful posts!
Overall Rating: 5 (1 ratings)
Correct Answer
David Hailey Sat, 05/08/2010 - 11:50
  • Purple, 4500 points or more
Hailey
