Ganesh Hariharan Mon, 05/10/2010 - 09:50
I'm trying to extend the range of an E3000 with a WAP4410N.  The E3000
was super easy to install, and the WAP4410N isn't.  Does anyone have a
good way to set one up?
Check out the below link for basic configuration note for WAP4410N
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap4410n/quick_start/guide/WAP4410N_QuickStartv1.pdf
Hope to Help !!
Ganesh.H
If helpful do rate the post
dukewoods Sun, 07/11/2010 - 11:55
Curious if you were able to get this working to your satisfaction.  I would like to extend the range of my E3000 as well and it appears the WAP4410N is the closest device to making this happen.
Thanks in advance for your response.
Related Content
