OEAP Problem
I have set up an 1131 AP for OEAP.  Everything is configured coeectly on the Controller, AP, and firewall.  I take the AP home and connect it to my network.  The AP connects to the controller as expected and broadcasts the WLAN's.
So that all appears to be ok.  The problem is when I connect to the WLAN, I never receive a DHCP address.  I thought it was my home equipment so I had another IT guy try and he had the same results.
Any ideas on what I may have missed or what the problem may be?
Surendra BG Sat, 05/08/2010 - 23:00
Where is the DHCP configured?? I request you to check the DHCP settings on the WLAN.. like OVERRIDE or the REQUIRED??
DHCP is configured on my home router.  i don't have any problems getting addresses on my home wireless/network.  The 1131 even receives one of my private IP's.
I do have DHCP set to required on the WLAN.  But that has not been a problem for any of the HREAP configured AP's.  I'll try disabling it and see what happens.
