vss dual supervisor per box
Greeting,
we need help and  documents for hardware and software requirements for configuring vss with dual supervisor per box
Jon Marshall
m.jawwad@123 wrote:
Greeting,
Mohammad
You can't do this as it is not yet supported with VSS. Cisco have said that it will eventually be supported but as far as i know at the moment you can still only run one supervisor per chassis with VSS.
Jon
Reza Sharifi
Hi Mohammad,
In addition to Jon's comment, I am tolled by Cisco IOS BU that dual sup for VSS will be available in SXI4.  The release date for it is around July 1st.
Reza
vvasisth
i gree at this moment dula sup in 1 chassis of VSS is not supported and will be available in the next IOS release
tentative date is july mid if i remember correctly.
Varun
