How to create subinterface on a 3560
May 9th, 2010
I am trying to create subinterfaces on a 3560 switch on gi0/1 interface..Can some please help? thank you !!!
current ios is flash:c3560-advipservicesk9-mz.122-44.SE2.bin"
I want to be able to create the following:
interface GigabitEthernet0/1.20
interface GigabitEthernet0/1.30
interface GigabitEthernet0/1.40
etc etc
I have used the no switchport on the gi0/1 interface as well and it keeps rejecting the command
Switch(config)#int gigabitEthernet 0/1?
.  :  <1-2>
Switch(config)#int gigabitEthernet 0/1.
Switch(config)#int gigabitEthernet 0/1.20
% Invalid input detected at '^' marker.
Switch(config)#
Switch#sh run
Building configuration...
Current configuration : 1330 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
description **** Create sub interfaces ***
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 5 15
end
Switch#
Reza Sharifi Sun, 05/09/2010 - 07:38
Unfortunately, you can not create sub-interface on 3560s or 3750s.
Reza
ud0508500 Mon, 05/10/2010 - 04:28
Thank you for the information..appreciate the help..it seems there are options
to do so with the IOS..but it just does not take..thanks
Jon Marshall Sun, 05/09/2010 - 07:55
You don't need to create subinterfaces on a L3 switch. Instead make the port a trunk port and then create a L3 SVI for each vlan you want to route eg.
int gi0/1
switchport mode trunk
int vlan 10
ip address 192.168.5.1 255.255.255.0
int vlan 11
ip address 192.168.6.1 255.255.255.0
etc. for each vlan. So where you would create a subinterface with an IP addressc create a L3 SVI as above.
Jon
ud0508500 Mon, 05/10/2010 - 04:35
Thanks for your help..appreciate everyones feedback and quick responce..thanks again!!!
