Error occurred while reading the resources on uccx 7.0
May 9th, 2010
Hi All,
I am running uccx in a HA mode on both the severs under RMCM > resources file it shows error occurred while reading the resources
i have also attached screenshot of the error along with this case.
waiting for your reply asap.
Thanks & Regards
Anthony Holloway Sun, 05/09/2010 - 20:34
  • Purple, 4500 points or more
I have this same issue every once in a while in the lab (not AD integrated).  I can usually just click the resource link again, then it shows them.  What version are you running?  I am on 7.0(1) SR5 in the lab.
shahnawaz.a Mon, 05/10/2010 - 01:09
Yes i am also running with same version 7.0(1) SR5 but
this error is showing me when i am configuring resources to a new agent if i go directly from RMCM it works fine
please let me know if some has solution on this.
Waiting for your replys.
Thanks & Regards
