BGP route filtering
May 9th, 2010
Here is the output before applying distribute-list
BGP table version is 3, local router ID is 1.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*>i192.168.2.0      1.1.2.1                  0    100      0 i
*>i192.168.20.0     1.1.2.1                  0    100      0 i
Here is the following configuration for BGP
ip prefix-list fp seq 10 permit 192.168.2.0/24 ------------  matches exact 192.168.2.0 255.255.255.0  sub-net
router bgp 100
no synchronization
bgp log-neighbor-changes
neighbor 1.1.2.1 remote-as 100
neighbor 1.1.2.1 update-source Loopback1
distribute-list prefix fp in Serial1/1   -----------------------> updates are received from ser 1/1
no auto-summary
the subnet 192.168.2.0/24 is not getting blocked.
I am able to block that subnet by route-map but not with distribute-list command.
Please share the experience
Subodh
Jon Marshall Sun, 05/09/2010 - 18:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
router bgp 100
no synchronization
no auto-summary
Subodh
Subodh
If you want to filter routes coming from a neighbor with a prefix list then you should do it this way -
ip prefix-list fp seq 10 deny 192.168.2.0/24
ip prefix-list fp seq 20 permit 0.0.0.0/0 le 32
router bgp 100
neighbor 1.1.2.1 prefix-list fp in
Jon
