C2821 ccme licience
May 9th, 2010
Hi all,
I want to add 20 staffs extension in our company. However, our existing C2821 ccme licience is 48 and I have used 40 licience. Could you tell me how to add more licience temporarily in C2821?
Leung Che Man
Jaime Valencia Sun, 05/09/2010 - 21:49
  • Cisco Employee,
  • Hall of Fame,
    2011
If you need 60 phones total, then you don't need a license, you need another ISR.
2821 can only have 50 phones as maximum. Older releases had 48 as max.
Compatibility Information
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_device_support_tables_list.html
Look at the version you want to use to see what ISR you need for at least 60 phones.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
