ipsec vpn ports?
May 9th, 2010
I will make a site to site vpn betweeen two asa firewalls. But I have a adsl modem in front of the firewall so I need to make nat for these ports which are used by vpn. so what are these ports ? which ports should I make nat for vpn ?
thanks
Kent Heide Mon, 05/10/2010 - 03:58
Most likely not possible on an ASDL modem and since he is doing NAT the solution would be as stated above to use NAT-T. Therefore pushing phase 2 up to udp/4500.
