Cisco Unified Enterprise Attendant Console
Answered Question
May 10th, 2010
Can anyone tell me if the Calendar view function is available in the CUEAC ver 8 with CUPS/Exchange intergration?
I ask as i have setup the CUPS and certificates to exchange but on the CUEAC client i cant seem to configure or have the option to add calendar view.
No information seems to be available in the docs either.
Any help would be great.
Correct Answer by Jonathan Schulenberg about 6 years 11 months ago
The Cisco Attendant Consoles have a CUPS integration that allow them to show presence from there. Since CUPS supports an Exchange calendar integration, you can indirectly see it that way.
The Arc Enterprise product is probably the correct choice If you want direct Exchange free/busy or OCS integration.
Overall Rating: 5 (2 ratings)
Jonathan Schulenberg Mon, 05/10/2010 - 08:18
  • Cisco Designated VIP,
    2017 IP Telephony
Exchange free/busy information was stripped from the Cisco OEM of the Arc products. The presumption appears to be that the customer has a CUPS server which performs the Exchange calendar integration and derives the presence from that.
paultruscott Tue, 05/11/2010 - 04:06
So CUEAC has no calendar view function? So how does the receptionist view calendar statues then? CUPC I guess. What if the site is using CUCIMOC.
Go with the ARC enterprise solution?
Correct Answer
Jonathan Schulenberg Tue, 05/11/2010 - 04:50
    2017 IP Telephony
