How to upgrade flash and merge 1 & 2 flash slot.
May 10th, 2010
Here i wont to upgrade the Flash currently in core switch(6509) 64MB is running.
On switch there 2 flash slot is present i wont to use both slot in run time.
Ple suggest how i can configured the both slot with 64 - 64 MB flesh..
Regards...
Leo Laohoo Mon, 05/10/2010 - 16:15
Let me get this straight.  You have a 64mb CF and you want to upgrade the CF or the IOS?  If you want to upgrade the CF, get a Type 2 CF with a size no bigger than 2Gb.
Don't forget to rate our useful posts.  Thanks.
