SRW248G4 issues
May 10th, 2010
Hello
I have switch SRW248G4. And he has issue with load configuration. I loaded firmware but without any result. Please help. I placed below logs from booting device.
------ Performing the Power-On Self Test (POST) ------
UART Channel Loopback Test........................PASS
Testing the System SDRAM..........................PASS
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.0.2 Built  17-Aug-2006  14:55:46
Linksys SmartSwitch based on 88E6218 with ARM946E-S.
32MByte SDRAM. I-Cache 8 KB. D-Cache 8 KB. Cache Enabled.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Preparing to decompress...
100%
Decompressing SW from flash
100%
OK
Running from RAM...
*** Running  SW  Ver. 1.2.1b  Date  31-Aug-2006  Time  13:47:21 ***
HW version is 00.03.00
Base Mac address is: 00:1a:70:2b:f6:58
Dram size is  : 32M bytes
Dram first block size is  : 16969K bytes Dram first PTR is  : 0xF6D840 Flash size is: 8M
01-Jan-2000 01:01:02 %CDB-I-LOADCONFIG: Loading startup configuration.
01-Jan-2000 01:01:04 %ERHG-F-SEND: BOXP_perform_smi_scan_of_devices_in_slot - fa iled reading device id on device 0
***** FATAL ERROR *****
Reporting Task: ROOT.
Software Version: 1.2.1b (date  31-Aug-2006 time  13:47:21)
