anomaly guard logs (Can't connect to managment module; SYSTEM IS NOT FULLY OPERATIONAL: Connection refused)
May 10th, 2010
when i want to configure guard module but some logs displaying. what is the problem and what am i do.
logs below thats;
[email protected]#conf terminal
Management module is busy. Please try again in 10 seconds
[email protected]#interface eth1
[email protected]#no sh
[email protected]#no shutdown
To complete the configuration change you must reload the software
Are you sure you want to reload? Type 'yes' to reload
yes
reloading...
null
Shutting down interface giga2:  [  OK  ]
Message from [email protected] at Mon May 10 08:52:05 2010 ...
localhost admin: RHInit FATAL: Bad CFE version ( 34). This version requires version 31  /* what does it mean
[email protected]#sh running-config
Can't write to socket
Error getting reactivate-after-reboot information
thanks.
