WS-X6748-GE-TX log : pm failed lock for admin change for Gix/x
Answered Question
May 10th, 2010
  • Silver, 250 points or more
Hello community,
I would like to know if someone has ever met this kind of log :
*May 10 09:28:49.416: pm failed lock for admin change for Gi9/18
I meet this log on a WS-C6509-E (s72033-ipservicesk9_wan-mz.122-33.SXH3a) on a Gig interface of a module WS-X6748-GE-TX in slot 9. I meet this log after 'no shutting' the interface even after I reset the interface to default configuration.
Thanks a lot.
Karim
Correct Answer by Laurent Aubert about 6 years 10 months ago
Correct. The full fix comes from two different bugs ID actually and only one of them is in SXH3a. You need SXH4 to be completely safe.
Laurent.
Overall Rating: 5 (2 ratings)
krahmani323 Mon, 05/10/2010 - 08:25
Hi Laurent,
Thanks a million for your answer, it seems we are 100% hitting this bug as we are doing a shut/no shut on the interface and loosing the access during approximately 2 minutes.
The only issue being the cisco bug details indicating the bug is fixed in 12.2(33)SXH3 (we are in SXH3a)......Maybe you have a different information in your internal databases stating the bug is resolved in SXH4 for the 6500..
Thanks again.
Karim
Correct Answer
Laurent Aubert Mon, 05/10/2010 - 09:03
  • Cisco Employee,
Laurent.
