How can you tell this interface is a static MAC address?
May 10th, 2010
Switch1#show mac-address-table
Dynamic Address Count:                 19
Secure Address Count:                  0
Static Address (User-defined) Count:   0
System Self Address Count:             41
Total MAC addresses:                   50
Non-static Address Table:
Destination Address  Address Type  VLAN  Destination Port
0010.0de0.e289               Dynamic              1          FastEthernet0/1
0010.7b00.1540              Dynamic              2          FastEthernet0/5
0010.7b00.1545              Dynamic              2          FastEthernet0/5
0060.5cf4.0076               Dynamic              1          FastEthernet0/1
0060.5cf4.0077               Dynamic              3          FastEthernet0/1
Switch1#show cdp neighbors
Capability Codes:
R - Router, T - Trans Bridge, B - Source Route Bridge
            S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
Switch2          Fas 0/1     157             s              2950-12  Fas 0/1
Switch3          Fas 0/2     143             s              2950-12  Fas 0/5
As you can see above, how do we know Fastethernet 0/5 has statically assigned MAC address?
Ko Is Mon, 05/10/2010 - 05:28
It seems that there is no address static from the command of "show mac-address-table".
If it is original, "Static Address (User-defined) Count:" will increase.
macky1313 Mon, 05/10/2010 - 06:57
Thanks for the reply.
According to this question:
A. A hub is connected directly to FastEthernet 0/5
B. FastEthernet0/1 is connected to a host with multiple network interface cards.
C. Interface FastEthernet 0/2 has been disabled.
D. Multiple devices are connected directly to FastEthernet0/1.
E. FastEthernet0/1 is configured as a trunk link.
F: Fast Ethernet0/5 has statically assigned MAC addresses.
My answer: A E.
Correct answer is E F
Do you think the answer suggested is wrong?
Ko Is Fri, 05/14/2010 - 06:16
"0010.7b00" -- since this is the MAC Address of Cisco, it is considered to be also Static.
Therefore, aren't E and F considered, either?
macky1313 Sun, 05/23/2010 - 20:12
Is this a fact that ""0010.7b00" is a static MAC address of Cisco?
Are there are any other static MAC address for Cisco routers or switch?
