VPN Configured With Aggressive Mode Enabled
Answered Question
May 10th, 2010
Can anyone tell me whatthe above message means and how to resolve it.
Correct Answer by Federico Coto F... about 6 years 9 months ago
The command will disable inbound aggresive mode connections.
If you want, there's an option to disable inbound aggresive mode connections on the tunnel-group as well.
tunnel-group xxxxxx ipsec-attributes
  isakmp am-disable
In this way you disable inbound aggresive mode connections from an specific peer.
If a peer tries to establish an aggresive mode connection, you should see a message like this in the logs:
''Unable to initiate or respond to Aggressive Mode while disabled''
This command will prevent Easy Virtual Private Network (Easy VPN) clients from connecting if they are using preshared keys because Easy VPN clients (hardware and software) use aggressive mode.
Federico.
Overall Rating: 5 (1 ratings)
Federico Coto F... Mon, 05/10/2010 - 06:50
Both Main Mode and Aggresive Mode are IKE Phase 1 exchange methods.
Main mode is the default and recommended (more secure) exchange method because it consists of six exchange messages.
Aggresive mode squeezes the IKE SA negotiation in three packets.
You can configure the device to use aggresive mode if needed or disable it.
What device are we talking about?
Federico.
networker101 Mon, 05/10/2010 - 07:17
This is on the ASA5520, how can i change them to normal mode?
Ellech
Federico Coto F... Mon, 05/10/2010 - 07:22
crypto isakmp am-disable
The above command disable inbound aggresive mode connections
Please rate helpful posts.
Federico.
Correct Answer
Federico Coto F... Mon, 05/10/2010 - 08:14
  isakmp am-disable
Federico.
