maximum calls on FXO E&M
May 10th, 2010
I would like to know how many simultaneous calls a single FXO and E&M Port supports. I understand both can be used to do trunking, I did some research but unable to find the max simulatenous calls limit on each of these two ports. Any document explaining this is highly appreciated.
Thanks in advance,
inner_silence
Overall Rating: 5 (1 ratings)
Aaron Harrison Mon, 05/10/2010 - 05:31
  • Community Spotlight Award,
    Member's Choice, May 2015
One port, one call.
Two port card, two calls.
Aaron
James Hawkins Mon, 05/10/2010 - 05:31
  • Blue, 1500 points or more
Each port type supports one concurrent call. If you need more th
an that you need to use a T1/E1 type circuit.
