New License after upgrade from WCS 4.2 to 6.x
Answered Question
May 10th, 2010
we are running an WCS to manage three WiSM Controller at our Company.
The WCS is State 4.2.128.0 with License Type "Base + Location".
Can we upgrade from our current State 4.2.128.0 to 6.x or do we need to buy an new License?
With best regards
Correct Answer by Lucien Avramov about 7 years 2 months ago
You can surely upgrade. You dont need a new license.
Just don't change the hostname of your server.
Make a backup of your database and then run the installer that will upgrade your WCS 4.2 to 6.x.
You can find more about the upgrade procedure here:
http://www.youtube.com/watch?v=0KQUfszmTJg
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Overall Rating: 5 (1 ratings)
sschmidt Mon, 05/10/2010 - 07:05
  • Cisco Employee,
If you already have a license for 4.2 you can use it in 6.x.
Correct Answer
Lucien Avramov Mon, 05/10/2010 - 07:06
  • Red, 2250 points or more
Trending Topics - Security & Network
