Error in replicating Directory Services
May 10th, 2010
Hello again, i still having some problems about replicating CAD server. I have a primary and secondary CAD server but when i run postinstall.exe with local administrator account, appers this error: "Error in replicating Directory Services".
Isn't not problem about firewall, because the servers ping one each other and i try to disable the firewall and I still having problem.
Someone can help me?
Directory Services is controlled through a service that runs a process called slapd.exe which builds an LDAP style database. The replication between LDAPs is controlled by slurpd.exe. Look in the logs and see if you can find the reason replication is failing. Maybe edit the INI files and set the log level to DEBUG and try stopping it with PostInstall.exe, which removes it, and adding it again. Look at the debugs.
Eric Alisson Mon, 05/10/2010 - 09:05
I fixed the problem.
Solution: Restart ther server B and enable the firewall exception.
