Microsoft NLB with 2 Switches
Answered Question
May 10th, 2010
Hello
I am about to configure NLB for my company. We have 2 sites a production and DR site.
I am going to configure my switch with static ARP entries as seen in
http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1006525
My question is:
Should I also configure my DR site switch with static ARP entries ,in case my entire production site goes down?
Or should I wait til it happens?
Thanks in advance
Dermot Cronin
Correct Answer by Giuseppe Larosa about 6 years 11 months ago
Hello Dermot,
it shouldn't create a problem the fake ARP entry associated the IP address of the cluster with this multicast MAC address, but this should be used as a discovery mechanism to find out active server.
Other colleagues have setup in this way having two servers in different switches.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Mon, 05/10/2010 - 08:07
  • Hall of Fame,
    Founding Member
Hello Dermot,
if you have a L2 connection to DR site that is always on it should be wise to add entries on it and to map the multicast MAC address also to the ports between them (HQ and DR)
Actually the idea is to use static entries in ARP table and in CAM table so you need to "full mesh" also the CAM entries
Hope to help
Giuseppe
cdtinfrastructure Mon, 05/10/2010 - 08:20
Hello Giuseppe
thanks for your response
As the link between the Production and DR Sites is always up, will I not risk creating an endless loop if I configure both switches with the static ARP entries?
Dermot
Correct Answer
Giuseppe Larosa Mon, 05/10/2010 - 10:02
  • Hall of Fame,
    Founding Member
Hello Dermot,
Hope to help
Giuseppe
