Tomcat service restarted without impact?
May 10th, 2010
I have a question about Cisco Tomcat: can we easily restart the Tomcat service without having impact on the telephony environment? I have found the next in the Serviceability Guide of CUCM:
Services That Use Cisco Tomcat
The following services use Cisco Tomcat for alarm generation:
•Cisco Extension Mobility Application
•Cisco IP Manager Assistant
•Cisco Web Dialer Web
The system login alarm AuthenticationFailed also uses Cisco Tomcat.
I states that it use Cisco Tomcat "for alarm generation". So the services like EM, IPMA & WebDialer aren't impacted?
Greets,
David
Overall Rating: 5 (4 ratings)
htluo Mon, 05/10/2010 - 08:19
  • Red, 2250 points or more
The answer is yes and no.
During restart, you won't be able to log into the IP phone services (ie. you won't be able to log into EM, etc.).  However, if you already logged in, you won't be affected.  Because HTTP is connectionless.
Michael
http://htluo.blogspot.com
david.vanherck Mon, 05/10/2010 - 08:29
I thought that everything that invokes http & https is out of service during the restart of the service. But it's good to know that the services using http or https aren't impacted, so logged in profiles stay logged in and can work. What when Directories, Services, Voice Mail & Settings is pressed on an IP Phone? These will fail too during the restart?
htluo Mon, 05/10/2010 - 08:30
Right.
Michael
david.vanherck Mon, 05/10/2010 - 08:33
OK, the restart should be done outside office hours then...
Thanks for helping me quickly! Really appreciate it! :-) Thx!
Greets,
David
David Hailey Thu, 07/28/2011 - 06:21
  • Purple, 4500 points or more
You can restart the Tomcat service via CLI independently.
Hailey
Please rate helpful posts!
Rob Huffman Thu, 07/28/2011 - 06:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Omar,
Our friend Hailey is most correct here (as usual!) +5
For Unity Connection
To restart the Cisco Tomcat service, use the CLI command
utils service restart Cisco Tomcat.
Then to check
utils service list
Cheers!
Rob
oattoumani Thu, 07/28/2011 - 06:39
Ok
but my question is not how to restart the service.
My question is to avoid an issue after restart cisco Tomcat, on Cisco Unity Connection with experiecing an "Except:Java.util.missingRessource....." .
what are the services (other than Cisco Tomcat) I must to check after restart and check the Cisco Tomcat..
thanks
Omar
David Hailey Thu, 07/28/2011 - 06:47
IMO, the best thing to do would be the following:
From CLI - "utils service list page" before restarting Tomcat.  Note the services that are started.
Restart Tomcat via CLI.  You can watch the status of it and other services by running the same "utils service list page" command.  When the service has restarted (might take a few minutes), just note the services that are started again.
For the most part, if I restart Tomcat for some reason - the first thing I do is attempt to login to an administration web page.  If the page loads, then you are generally OK.  If it doesn't, then that's the first hint of an issue.  When you restart Tomcat, you (and users) will not be able to connect to the Unity Connection server via HTTP/HTTPS (administration web pages, end user web pages, etc).
Hailey
oattoumani Thu, 07/28/2011 - 07:28
Thanks Hailey for your helps;
I am going to apply your procedure.
Omar
