SA500 IPSEC Client connection
May 10th, 2010
Having some trouble getting ipsec remote access working.
I have an avaya 5610 vpn phone (which has a built in vpn client, that uses ipsec)
I typically use an ASA 5510 for this type of setup, but with the backorder on ASA's, we delivered an SA500 onsite.
When testing, the phone never seems to get passed phase1
So I tried using Cisco's VPN client software 5.0.5 from my PC.
I still could not connect.
the log within the vpn client displays:
Cisco Systems VPN Client Version 5.0.05.0280
Copyright (C) 1998-2009 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 6.1.7600
Config file directory: C:\Program Files\Cisco Systems\VPN Client\
1      11:42:01.286  05/10/10  Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with 72.20.157.84.
2      11:42:01.291  05/10/10  Sev=Info/4 IKE/0x63000001
Starting IKE Phase 1 Negotiation
3      11:42:01.298  05/10/10  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 72.20.157.84
4      11:42:01.921  05/10/10  Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
5      11:42:01.921  05/10/10  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
6      11:42:06.492  05/10/10  Sev=Info/4 IKE/0x63000021
Retransmitting last packet!
7      11:42:06.492  05/10/10  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (Retransmission) to 72.20.157.84
8      11:42:11.563  05/10/10  Sev=Info/4 IKE/0x63000021
9      11:42:11.564  05/10/10  Sev=Info/4 IKE/0x63000013
10     11:42:16.634  05/10/10  Sev=Info/4 IKE/0x63000021
11     11:42:16.634  05/10/10  Sev=Info/4 IKE/0x63000013
12     11:42:21.705  05/10/10  Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=D92BA7834E762FDC R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
13     11:42:22.205  05/10/10  Sev=Info/4 IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=D92BA7834E762FDC R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
14     11:42:22.228  05/10/10  Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
15     11:42:22.719  05/10/10  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
16     11:42:22.719  05/10/10  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
17     11:42:22.719  05/10/10  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
18     11:42:22.719  05/10/10  Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
the log under the SA500 vpn client displays:
2010-05-10 16:19:47: ERROR:  Could not find configuration for 72.20.157.5[29303]
2010-05-10 16:19:52: ERROR:  Could not find configuration for 72.20.157.5[29303]
2010-05-10 16:19:57: ERROR:  Could not find configuration for 72.20.157.5[29303]
2010-05-10 16:20:02: ERROR:  Could not find configuration for 72.20.157.5[29303]
2010-05-10 17:13:19: WARNING:  no phase2 found for "test"
2010-05-10 17:13:19: INFO:  IPSec configuration with identifer "test" deleted sucessfully
2010-05-10 17:16:27: INFO:  Adding IPSec configuration with identifier "test"
2010-05-10 17:16:27: ERROR:  Failed to load the configuration
2010-05-10 17:21:04: ERROR:  Could not find configuration for 72.20.157.5[57048]
2010-05-10 17:21:09: ERROR:  Could not find configuration for 72.20.157.5[57048]
2010-05-10 17:21:15: ERROR:  Could not find configuration for 72.20.157.5[57048]
2010-05-10 17:21:20: ERROR:  Could not find configuration for 72.20.157.5[57048]
I spoke with cisco smbs support. they stated you could only use SSL as a means to connect via client to the SA500.
Is this the case?
Any assistance is greatly appreciated.
Related Content
