Service Objects and Groups in ASDM
Answered Question
May 10th, 2010
I have been using ASDM for some time
now.  I have always had a quesiton about what exactly Service Groups are that are built using the Service type TCP/UDP vs.  ones that are specifically TCP or UDP.  Out of fear I have always built Service Groups for TCP only or for UDP only.
Lets say I need a Service Group that needs ports 102, 20000, and 21000 in it, but I am unsure if the ports need to be UDP or TCP.  If I create the Service Group using type TCP/UDP, will it allow both TCP and UDP in for the specific port?
Kevin
Correct Answer by Jon Marshall about 6 years 9 months ago
Kevin
Kevin
Yes it would. In fact that is exactly what service objects are used for ie. so you don't have to create 2 separate groups, one for TCP and one for UDP. So you would configure "object-group service tcp-udp" and then simply use service-objects to add your ports.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 05/10/2010 - 10:26
Kevin
Kevin
Jon
