CISCOWORKS - RME netconfig error
May 10th, 2010
When I go to RME>Config Mgnt>NetConfig>User-Define Task i receive the follow error:
CFG0053: No User-defined tasks are available.
I don't can do any configuration.
the version of RME is 4.1.1 and the licence is for 100 equipments, I must update the module? or someone know why appear this error?
readytolearncisco Mon, 05/10/2010 - 12:29
Hi Harold,
You need to create a user-defined task, which you'll find on the menu on the left.
harold.morales Mon, 05/10/2010 - 13:14
I think the problem is more serious
as seen, does not allow me create any task: in the menu, "Tasks" on the left can not deploy any device.
When i go create a task in RME>Config Mgmt>Netconfig>Netconfig jobs i cant not select ALL the devices as shown in the picture below: the host ING_C58_Sw_P2_03 can not choose, instead the other can choose
which will be the cause?
