Jatin Katyal Tue, 05/11/2010 - 06:22
Hi Pankaj,
I think, you want that user should be authenticated by active directory database whenever they login to the router using telnet/ssh. Well, if that is the case then you have to integrate router with some external radius server, that could be Microsoft IAS. Now here we need to integrate AD with IAS or we can make our AD (domain controller) as a radius server.
On the router you only need to issue couple of commnads;
aaa authentication login default group radius local
radius-server host key
username privilege 15 password
For IAS side configuration, please check the below listed document;
http://articles.techrepublic.com.com/5100-10878_11-6180954.html?tag=leftCol;articleText
JK
Plz rate helpful posts-
Related Content
