Utilizing 2960 switches for Mb network
May 10th, 2010
I have a situation to setup a network of workstations to communicate in Gb speed using the existing 62.5/125 MM fibre infrastructure between 3 buildings separated by a distance of 300m. I am thinking of using the Gb uplink ports in the Catalyst 2960 switches to set up the Gb network. Each building has a 2960 series switch and they are networked via the fibre GLC-LH-SM transceiver module installed in the uplink ports . Question is can the remaining free Gb ports not associated with the used fibre ports be for the workstations? The attachment shows the proposted connectivity, Thanks.
Reza Sharifi Mon, 05/10/2010 - 13:40
Hi shaiva,
You can, if the NIC on your workstation is fiber Gig then you connect it directly to the switch.  If the NIC on your workstation is copper then you need a 10/100/1000 media converter to convert from copper to fiber and then connect it to the switch.
Reza
Ganesh Hariharan Mon, 05/10/2010 - 23:47
I
As suggested you can use the free gb ports if your end station also have the fiber supported nic or fiber converter at station to support the fiber connectivity.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
