WAP keeps using recovery image
May 10th, 2010
Hi, i have 10 access point connected to PoE switch. 9 out of 10 wap are working ok. the 10th ap cannot get conencted to the WLC.
It get IP address, i can see it listed sh cdp neigh at the switch.
the switch is providing power to WAP
Tried to use different switch port with no luck.
Looks like the WAP is using recovery image.
Any ideas would be appreciated.
POE_SW1#sh cdp neigh detail
Device ID: AP0022.bd1a.426b
Entry address(es):
  IP address: 10.72.190.22
Platform: cisco AIR-LAP1142N-A-K9   ,  Capabilities:
Interface: FastEthernet0/10,  Port ID (outgoing port): GigabitEthernet0
Holdtime : 152 sec
Version :
Cisco IOS Software, C1140 Software (C1140-RCVK9W8-M), Version 12.4(18a)JA, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 21-Nov-08 01:28 by prod_rel_team
advertisement version: 2
Duplex: full
Power drawn: 14.500 Watts
Power request id: 45951, Power management id: 0
Power request levels are:14500 0 0 0 0
Management address(es):
Device ID: PER-AP494b
Entry address(es):
  IP address: 10.72.190.15
Platform: cisco AIR-LAP1142N-A-K9   ,  Capabilities: Trans-Bridge
Interface: FastEthernet0/7,  Port ID (outgoing port): GigabitEthernet0
Holdtime : 175 sec
Version :
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 12.4(21a)JHA, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 11-Feb-10 12:19 by prod_rel_team
Duplex: full
Power drawn: 15.400 Watts
Power request id: 50788, Power management id: 2
Power request levels are:15400 14500 0 0 0
Leo Laohoo Mon, 05/10/2010 - 16:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
If your WLC is still not yet in production, upgrade to the 6.X IOS.  This version is alot better than the 5.X when it comes to AP looking for the WLC for the first time.
If you are running this version already, console into the AP and in enable mode run the following commands:
1.  clear lwapp private-config;
2.  clear lwapp ap controller ip address
3.  lwapp ap controller ip address
endpoint Mon, 05/10/2010 - 23:05
Thanks leolaohoo. I will try suggested steps.
I tried two WAPs already with same results, both APs are brand new, out of the box. Do you think this can be the case that two APs are not behave OK? I put them in different switch port with same results.
craig.eyre Thu, 01/05/2012 - 07:49
I was just wondering if you found a solution for the above problem. I'm seeing the same thing.
3750 PoE sees ap with cdp neighbor and gets ip address but it looks like the ap won't get the the full 15.4watts of power and always pulls 14.5watts and never fully boots. Like endpoint mentioned, I have a couple other ap's on same switch that don't have a problem. I've swapped out the ap for another new one and still the same end result.
12.2(55) SE4 code on 3750G-24PS
Craig
Stephen Rodriguez Thu, 01/05/2012 - 07:52
  • Purple, 4500 points or more
what type of AP and what is the recovery code on the it?
Pulling less than 15.4w shouldn't matter until the AP is up and running, and I've seen the 1130/1240 pull 13.4w or so, and still work fine.
Steve
craig.eyre Thu, 01/05/2012 - 08:05
Stephen,
Not sure what recovery code is on the 3502i ap as its brand new out of the box and has never been connected to the controller.
Craig
Scott Fella Thu, 01/05/2012 - 08:04
  • Hall of Fame,
    2017 Wireless
Have you tried to swap the ap to the same port as one that is working. I have seen that also when we had bad cabling or a bad patch cord.
Scott Fella
Sent from my iPhone
craig.eyre Thu, 01/05/2012 - 08:08
Scott,
I didn't try one of the currently working ap ports but I took the originally bad ap(brand new deployment) and a brand new ap into the wiring closet and plugged them directly into the original port and also tried 2 other ports on the same switch and same result.
Craig
endpoint Thu, 01/05/2012 - 08:13
I was able to get it running under different WLC. First i statically applied IP address to AP, then i moved to different WLC and for some reason it was working fine after even doug i did not change the actuall switch where this ap was connected to. So, i did not dig further...
thanks guys for all your help..
endpoint Thu, 01/05/2012 - 08:14
I was able to get it running under different WLC. First i statically applied IP address to AP, then moved to different WLC and for some reason it was working fine after even dough i did not change the actually switch where this ap was connected to. So, i did not dig further...
craig.eyre Thu, 01/05/2012 - 09:47
Hey All,
I have to hang my head in shame to some degree. I consoled into one of the ap's having this issue and noticed that it was failing the to resolve the cisco-capwap-controller dns entry. I entered in the command capwap ap controller ip address X.X.X.X and the ap booted.
The strange thing is that I have multiple ap's in the same address space that have worked flawless with this design.
Will keep an eye on it and note it in the forum if it keeps reocurring.
Craig
endpoint Thu, 01/05/2012 - 10:15
Sorry for no reply for long time...
I was able to get it running under different WLC. First i statically applied IP address to AP incuding WLC IPand other info, then moved it to different WLC and for some reason it was working fine after even dough i did not change the actually switch where this ap was connected to. So, i did not dig further...
