Not able to ping or access Internet through asa 5505 firewall
sivapkd100
I am new to ASA 5505 firewall. I just configured what I learnt from the internet. However I am not able to access internet.
I can ping default gateway from any host, but I cannot ping Outside interface or beyond that.
Please see the configuraion below and help me to fix the issue.
Sivakumar
ASA Version 7.2(4)
hostname ciscoasa
domain-name default.domain.invalid
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 63.193.24.33 255.255.255.248
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
ip address 10.10.10.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 3
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service DM_INLINE_TCP_1 tcp
port-object eq domain
port-object eq ftp
port-object eq www
port-object eq https
port-object eq nntp
port-object eq pop3
object-group icmp-type DM_INLINE_ICMP_1
icmp-object echo
icmp-object echo-reply
icmp-object time-exceeded
icmp-object timestamp-request
object-group icmp-type DM_INLINE_ICMP_2
icmp-object echo
icmp-object information-reply
icmp-object timestamp-reply
access-list inside_access_in extended permit tcp any any object-group DM_INLINE_
TCP_1
access-list inside_access_in extended permit icmp any any
access-list inside_access_in extended permit icmp any any object-group DM_INLINE
_ICMP_1
access-list outside_access_in extended permit icmp any any object-group DM_INLIN
E_ICMP_2
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:ef1cdf5444b6d88b8ccb42f19a3426f4
: end
Jennifer Halim
1) Default gateway on the ASA is set incorrectly. The ASA outside interface ip is 63.193.24.33, and currently the default gateway is configured to be:
Pls change it to the next hop of your ISP address (should be something in the 63.193.24.32/29 subnet):
route outside 0.0.0.0 0.0.0.0 63.193.24.x
2) To be able to ping through the ASA, pls add the following:
          inspect icmp
You can't ping the ASA outside interface ip from the inside network. It's not allowed by default.
Hope that helps.
Thanks for the reply.
I have changed as per your suggestions, still I am not able to ping 63.193.24.38 which is the ISP router interface. Any more suggestions? Thanks.
Here is the current configuration.
ASA Version 7.2(4)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Vlan3
nameif dmz
security-level 50
ftp mode passive
port-object eq ftp
port-object eq www
port-object eq nntp
port-object eq pop3
icmp-object echo
icmp-object echo
TCP_1
_ICMP_1
E_ICMP_2
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu dmz 1500
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 63.193.24.38 1
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
Cryptochecksum:02442be367c4f2b89f67a644240bf2e1
: end
Please confirm if you can ping next hop (ISP Router) from ASA ; you would need 'icmp permit any outside" on ASA.Also try to ping 4.2.2.2 which is Global DNS Server from ASA and let us know the results .
Pls issue "clear xlate" and "clear arp" on the ASA firewall, and test again.
