cannot connect to port 47 in 2948G
May 10th, 2010
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
hello
I was stuck without as CATOS for my 2948g - and now I have one
Being all happy that I can finally put get my system back on it's feet,
Brought the system up to rommon, condole cable connected - and terminal working,
but - now I have no connectivity with port 47, which is as far as i know used for restoring the system -
it was perfectly working before in the rommon state, ans I had layer 3 connectivity as well - managed to connect to a TFTP ( only at that time I had no matching
CATOS to load.)
the cables i'm connecting connect with no problem with same PC to different switches, including another 2948g.
any ideas ?
Thank you
Ganesh Hariharan Mon, 05/10/2010 - 23:49
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
hello
CATOS to load.)
any ideas ?
Thank you
Hi ,
If you want to restore the switch configuration check out the below link for more information:-
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800c4546.shtml
Hope to help !!
Ganesh.H
guy.tetru Tue, 05/11/2010 - 06:51
well. this is embarrassing
it is not the first 2948G, and it got stuck i my head, for same non understandable reason that port is 47,
no it's not. the right one to use is the 10M mgt port, right under the console one, so problem is resolved
Thank you
