David Hailey Mon, 05/10/2010 - 20:35
http://www.cisco.com/en/US/docs/routers/access/vg224/software/configuration/guide/scg.html
This is the IOS configuration.  The key command is the stcapp comman - this enables the SCCP features. When you add the gateway in CUCM, it should be fairly straightforward on how you add the actual ports.  Since you are using SCCP, it looks pretty much like most other phone configurations.
Hailey
Please rate helpful posts!
Related Content
