Alternative for Auto QoS for 2960-PST-S?
May 10th, 2010
We are looking at purchasing a bunch of 2960-PST-S (Lan_Lite) switches for one of our sites. Our current VoIP system uses ' /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";} auto qos voip cisco-phone’ on 3560 switches.
The 2960'S do not support 'Auto QoS' - Is there an alternative to AutoQos that we can configure on the 2960-pst-s interfaces?
Cheers
Brendan
paolo bevilacqua Tue, 05/11/2010 - 01:20
  • Hall of Fame,
    Founding Member
Do not configure anything, you will find that things work perfectly anyway.
