Error in adding Data Points in WCS when using Intel 5100 AGN card
May 10th, 2010
I am using Wireless Control System (WCS) 6 and when I try to add data points in a custom calibration model I created, I get an error message "No data points collected when starting from location (X,Y)" only when using Intel 5100 AGN as the client. I know that in order to add Data Points, I need to have a wireless card that supports Cisco CCX, this Intel card supports CCX 4.
I have done added data points using my older computer that uses an older Intel card and it works fine. I used another computer that has a Dell Wireless 1510 Wireless-N card and it works too. The driver on the Intel 5100 AGN is
Is there a solution to this or is the Intel 5100 AGN just not supported?
Lucien Avramov Tue, 05/11/2010 - 01:54
There is probably something with the card and the CCX support.
Have you tried to do a wireless packet capture to make sure it does indeed support CCX?
We dont test other vendor nic cards for the driver / feature reason, it makes it about impossible to track all the NIC cards, hence we recommend the card we have since we know that the driver is correct.
Please support CSC Helps Haiti
Related Content
Trending Topics - Security & Network
