3G Router PCEX-3G-HSPA configuration problem.
May 11th, 2010
I am trying configure to Cisco 880 3G Router (PCEX-3G-HSPA=F1_2_3_22AP C:/WS/F) ***Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 12.4(22)YB5, RELEASE SOFTWARE (fc2)*** but i have a problem about the configuration. 3G interface status is up and it is also registered with our SP (Turkcell - Turkiye) without any username&password, when i talked the SP they said that "you dont have to use username&password" so everything seems to be ok (i mean interface status, cell id, sp name, etc.) but profile status "INACTIVE" (as you can see the following output)
Note that; I am also change the APN name, i tried all the possibilities (our SP using different APN name for example "mgb","mgbs", "internet") and another important point is when i tried connect to internet with USB 3G device (with my computer) its wotking (i mean SIM card is working.)
Can anyone help me about this problem.
My best.
Router#sh cell 0 all
Hardware Information
Modem Firmware Version = F1_2_3_22AP C:/WS/F
Modem Firmware built = 06/22/09
Hardware Version = 1.1
International Mobile Subscriber Identity (IMSI) = 286015233707406
International Mobile Equipment Identity (IMEI) = 356812011562301
Factory Serial Number (FSN) = D46332820931142
Modem Status = Online
Current Modem Temperature = 27 deg C, State = Ntrmal
Proile Information
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = internet
Authentication = None
Username: , Password:
* - Default profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
        Inactivity Reason = Normal inactivate state
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = UMTS/WCDMA (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = TUR, Network = TCELL
Mobile Country Code (MCC) = 286
Mobile Network Code (MNC) = 1
Location Area Code (LAC) = 60306
Routing Area Code (RAC) = 1
Cell ID = 2109
Primary Scrambling Code = 60
PLMN Selection = Automatic
Registered PLMN = TR TURKCELL , Abbreviated = TCELL
Service Provider =
Radio Information
Current Band = WCDMA 2100, Channel Number = 10612
Current RSSI(RSCP) = -95 dBm
Band Selected = Auto
Number of nearby cells = 1
Cell 1
        Primary Scrambling Code = 0x3C
        RSCP = -99 dBm, ECIO = -5 dBm
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of Retries remaining = 3
Router#
Balakrishnan Rajvel Tue, 05/11/2010 - 01:16
Please check out without service provider what APN they are using.
whether profile and chat script is created in router ?
Profile should be in below format
Router# cellular gsm profile create
profile number> <apn>
Chat script should be in below format
chat-script <script name> "" "ATDT*98*<profile number>#" TIMEOUT <timeout value> CONNECT
Note :  Even my service provider dont have username and password in that case we are using Mobile number or phone number as username and password.
Ali Cavit Davutoglu Tue, 05/11/2010 - 01:34
I have already configured chat script
chat-script TURKCELL "" "ATDT*99*1#" TIMEOUT 30 CONNECT (in our region 99) and also correct APN name is "mgb"... but it isnt working.
I also checked debug output but i could not find any significant information. Could you share the config example that you configured before?
Balakrishnan Rajvel Tue, 05/11/2010 - 03:06
Hi ,
Please try by removing the GPRS card and reinsert it.  after doing this you need to create the profile again.
Note : For most of cases it had worked in my setup...
