Supervisor Work Flow Administrator
May 11th, 2010
Hi all,
According to the following PDF on Page 53:
I followed the setup guide of Supervisor Work Flow Administrator
But it seems there is no respond after i made some calls to the CSQ ...
I am currently using Unified CCX Premium License, ...
Do I need Unified IP IVR license ???
Or do I miss any other setting in other areas ?
Anthony Holloway Tue, 05/11/2010 - 14:07
I just followed it myself, and it worked right away.  I am on UCCX Premium, so no, you don't need IP IVR.
Remove the config, and try again, you may have just missed a step.
I change IP address CRA server
WorkFlow not working!
How I change IP address for WorkFlow default group?
This solution not help me!
The DataFields.ini file does exist and       the connection to server works. Therefore, when you check the permission to the       file, you find that the Administrator user is not allowed to share the       C:\Program       Files\Cisco\Desktop_Config\config\ag_default directory where       the DataFields.ini file is located.
Add the Administrator user to the share list for the       C:\Program       Files\Cisco\Desktop_Config\config\ag_default directory in order       to solve this problem. Complete these steps:
  1. Navigate to the C:\Program             Files\Cisco\Desktop_Config\config\ag_default directory.
File DataFields.ini does exist, but WorkFlow search this file in old IP server.
Related Content
