i have change uc 520 config-register 0x2101 by mistake
ekhan
i have change uc 520 config-register 0x2101 after i couldnt connect to router uc please help show me step how to set again in normal
config-register 0x2102
David Harper
Can you connect to the uc500 now?  Either by telnet/ssh or by console?
If you can telnet/ssh or you connect by console and get a normal IOS prompt, then go into config mode and enter the following command:
Otherwise connect to the console and see if you are getting a rommon> prompt.  If so, enter the commands:
confreg 0x2102
reset
And all should be good.
Cheers,
Dave.
thx second option its work for me
