Outgoing call dropping after few second
May 11th, 2010
Hello  All,
We have using Cisco UC520 Router with two analog line, I did just trying to make an outbound call and I have found that it is dropping the call after approx 10 seconds, Have the same issue with calls disconnecting, in that the line goes dead ranges from 2 – 10 mins However the LED on the UC520 showing which line is busy, stays on and gives a busy signal if trying to use the line again, I had a call last about 10 mins yesterday,yet tried one this afternoon it disconnected after ringing three times
before the call was even connected generally seems to get through 2-3 mins.
can anyone suggest me, What could be the problem there,
